LAYON command
Turns on all layers in the drawing.
Icon:
Turns on all layers in the drawing to view and edit entities on those layers.
There are no prompts. The Command line indicates: all layers have been turned on.
Note: Entities on frozen layers are only visible if you also thaw
the layer. Entities on locked layers are only editable if you also unlock the
layer.
