LEADER command
Draws leaders.
Alias: LE, LEAD
Draws leaders by specifying several points.
Note: After you start creating a leader, options regarding the
annotation may be available.
Options
- Format
- Specifies the leader style.
- Arrow
- Draws an arrowhead at the leader’s start point (default).
- None
- Does not draw an arrowhead.
- SPline
- Draws the leader as a spline.
- STraight
- Draws the leader as a straight-line segment (default).
- Undo
- Undoes the last leader line segment.
- Annotation
- Starts adding text to the end of the leader line.
- Block
- Select a block in the drawing or upload a block file from the computer.
- Copy
- Select a Mtext, text, block reference or tolerance object from the drawing to use as annotation of the leader.
- None
- The leader command closes without annotation.
- Tolerance
- Enter the annotation as a tolerance notation through the geometric tolerance dialog box.
- Mtext
- Enter annotation as Mtext through a text formatting toolbar.
