LIGHT command
Places light glyphs in drawings for generating more realistic renderings.
Icon:
Alias: LIGHTING
Note: Set DEFAULTLIGHTING system variable OFF to take into consideration the active lights sources defined in the drawing. Otherwise, only the default lighting will be used.
选项(O)
- 点
- Creates a point light.Note: See the POINTLIGHT command for the meaning of its options.
- 聚光灯
- Creates a spot light.
- 网络
- Creates a web light.
- 远光源
- Creates a distant light.
