LINE command
Creates line segments.
Icon:
Alias: 3DLINE, L
描述(D)
Creates a series of individual line entities by specifying the start and endpoint of each segment. Options allow you to specify the angle, undo, and close the geometry.
  1. 起点
  2. 结束
  3. 关闭
  4. 长度
  5. 圆弧(A)
Methods to begin a line
This command has 3 methods to begin creating a line segment:
  • 指定线起点
  • 最后点
  • 跟随
You can continue adding unlimited segments until you press Enter to end the command.
指定线起点
Begin creating a line by specifying the start point then:
Set end point
Specify the end point of the line segment.
Additional options: [Angle/Length/Follow/Close/Undo]
最后点
Begin creating a line from the last point picked then:
Set end point
  1. Last drawn arc
  2. 最后点
  3. 终点
跟随
Begin creating a line from the last drawn arc or line segment, following its angle, then:
指定线长度
Specify the length of the line. Picking the endpoint only determines the length since the angle follows the previous segment.
  1. Last drawn arc
  2. 跟随
Options within the LINE command
After you begin creating a line, the following options may be available:
角度
Specify the angle of the line segment.
长度
Specify the length of the line segment.
撤销(U)
Undo the last line segment and continue drawing from its previous start point.
关闭
Automatically draw a line from the end point of the last segment to the start point of the first segment.
