LOFT command
Creates 3D solids or 3D surfaces.
Icon:
描述(D)
Creates 3D solids or 3D surfaces passing through 2 selected cross sections.
选项(O)
- 模式
- Determines if the resulting loft is a solid or a surface.
- 实体(S)
- Creates lofts as solid.
- 曲面
- Creates lofts as surfaces.
- 导引
- Uses both cross-sections and guide lines between the selected cross sections to create the loft.
- 路径
- Specify the path curve.
- 仅限断面
- Uses only cross section entities to create the loft, and no guides.
- 设置(S)
- Sets variables that affect how the loft is constructed.
- 直面纹
- Draws straight surfaces between the cross sections, features sharp edges at each cross-section.
- 平滑拟合
- Draws smooth surfaces between the cross sections.
- 法线指向
Draws surfaces normal to the chosen cross sections. Select one of the options to become one of the following results:
- 起点
- 两者(B)
- 结束
- 全部
- 拔模角度
- Specifies the angles at the starting and ending cross-sections to modify the loft shape.
