LOGFILEON command
Turns on log file recording.
Note: Log files record all prompts from the program and all your keyboard input. It does not record mouse actions or other non-keyboard activities.
BricsCAD records all command text to the LOG file located in the folder specified by the LogFilePath system variable. The default name of the file is "drawingname_year-month-date_hour-minutes-seconds.log", such as drawing1_2029-08-31_08-32-46.log. Setting the LOGFILEMODE system variable to 1 has the same effect as the LOGFILEON command. You can open the resulting log file in Notepad or another text editor.
