LOOKFROM command
Toggles LookFrom widget.
BricsCAD Shape; BricsCAD Pro; BricsCAD Mechanical; BricsCAD BIM
Alias: NAVVCUBE
Changes the display of the LookFrom widget between on and off, and accesses the settings for displaying the widget.
Methods
There are two methods to control the widget:
  • ON/OFf - toggle the widget’s display.
  • Settings - adjust the widget’s look, by accessing the LookFrom Control section of the Settings dialog box.
