MATCHPERSPECTIVE command
Matches the current model space view with a background image.
BricsCAD Shape; BricsCAD Pro; BricsCAD Mechanical; BricsCAD BIM
Matches the viewpoint of model space with the apparent perspective view provided by a background image, after three or more pairs of matching points are selected.
Before starting this command, place an image in the drawing with the BACKGROUND command, and then switch the viewpoint to perspective mode with the PERSPECTIVE variable.
