MATCHPROP command
Copies selected properties and styles from one entity and applies it to one or more entities.
Icon:
Alias: MA
Method
Select the entity whose properties will be copied and the entities to apply the properties to.
Options
Settings
Specifies which settings to be copied. The Match Properties dialog box lists applicable properties along with their current value.
Check all properties that may be applied on other entities so not all properties are automatically matched.
