MINSERT command
Inserts a block as a rectangular array.
Inserts a block as a rectangular array. It is a combination of the –INSERT and -ARRAY commands and creates a MInsert Block entity.
Options within the command
Block to insert
Specify the name of the block to be inserted.
Displays the Insert Block dialog box.
Insertion point for block
Specify the insertion point of the selected block.
Scale
Allows to set the X and Y scale factor equally.
Corner
Specifies the size of the block by picking a second point.
X scale
Specifies the scale factor of the block in the x direction.
Y scale
Specifies the scale factor of the block in the y direction.
Z scale
Specifies the scale factor of the block in the z direction.
Rotate
Specifies the rotation angle of the block around its insertion point.
Multiple blocks
Allows to insert a rectangular array of multiple blocks.
Number of rows in the array
Specifies the number of rows.
Note: To insert a linear array, enter 1. To draw the array downwards, enter a negative number.
Number of columns in the array
Specifies the number of columns.
