MIRROR3D command
Mirrors entities about a mirror plane in 3D space.
Icon:
Alias: 3DMIRROR, 3DM
Creates a mirror copy of selected entities in three-dimensional space.
Options within the command
Entity
Defines the mirror plane by extrusion direction.
Note: This option does not work with flat entities or 3D solids. To give an entity an extrusion, use the Properties panel's Thickness option.
Last
Reuses the last mirror plane.
View
Defines the mirror plane as the current view plane.
Z axis
Defines the mirror plane by the z axis and a point on the view plane.
X-Y plane
Specifies the mirror plane as the x,y plane.
Y-Z plane
Specifies the mirror plane as the y,z plane.
Z-X plane
Specifies the mirror plane as the z,x plane.
3 points
Defines the mirror plane by three points.
Delete the original entities?
Determines whether the original entities are erased or not.
