MKLTYPE command (Express Tools)
Creates a linetype based on selected entities.
Icon:
Method
Opens the MKLTYPE - Select Linetype file to create dialog box that allows you to save the linetype definition.
To create the linetype definition:
  1. Specify the linetype name.
  2. Specify a linetype description.
    Note: Press Enter to leave this field blank.
  3. Specify a start point (1) for line definition.
  4. Specify an end point (2) for line definition.
  5. Select the entities you want to use (3 and 4).
The linetype is automatically loaded in the current drawing.
