MLEADERCOLLECT command
Collects two or more multiline leaders into a single leader.
Icon:
Collects two or more multiline leaders into a single leader in a horizontal or vertical arrangement. The leaders can be sorted alphabetically.
Note: The command only works with mleaders that have blocks as content.
Method
There are five methods to collect multileaders:
  • Vertical
  • Horizontal
  • Wrap
  • Sorting
  • Collapsing
Options within the command
Vertical
Arranges the content blocks vertically to a single leader.
Horizontal
Arranges the content blocks horizontally to a single leader.
Wrap
Arranges the content blocks horizontally to a maximum width, and then places the remaining blocks in the row below.
Sorting
Sorts the content by name.
None
Does not sort the blocks.
Ascending
Sorts from A to Z.
Descending
Sorts from Z to A.
Collapsing
