MLEADERCOLLECT command
Collects two or more multiline leaders into a single leader.
Icon:
Collects two or more multiline leaders into a single leader in a horizontal or vertical arrangement. The leaders can be sorted alphabetically.
Note: The command only works with mleaders that have blocks as
content.
Method
There are five methods to collect multileaders:
- Vertical
- Horizontal
- Wrap
- Sorting
- Collapsing
Options within the command
- Vertical
- Arranges the content blocks vertically to a single leader.
- Horizontal
- Arranges the content blocks horizontally to a single leader.
- Wrap
- Arranges the content blocks horizontally to a maximum width, and then places the remaining blocks in the row below.
- Sorting
- Sorts the content by name.
- None
- Does not sort the blocks.
- Ascending
- Sorts from A to Z.
- Descending
- Sorts from Z to A.
- Collapsing
