MOCORO command (Express Tools)
Moves, copies, rotates or scales entities.
Icon:
Method
Select the entities and specify a base point.
Options within the command
Move
Allows you to move the selected entities.
Copy
Allows you to make a copy of the selected entities.
Rotate
Allows you to rotate the selected entities around the specified base point.
Scale
Allows you to scale the entities.
Base
Allows you to select a new base point.
Undo
Undoes the last change.
