MOVE command
Moves entities.
Icon:
Alias: M
Moves entities by specifying the starting point and the destination.
  1. Base point
  2. Second point
  3. Displacement distance
Options within the command
Displacement
Specify the displacement vector (the distance at which to position the copy). ‘Vector’ means that you specify the distance and angle at the same time.
Note: When Dynamic Input Mode is active, you can type a distance and angle in the dynamic input fields.
