MTEXT command
Places text in a bounding box.
Icon:
Alias: MT, T
描述(D)
Places formatted, paragraph text in a bounding box that limits the extent of the text.
After specifying the limits of the text bounding box, the Text Formatting toolbar opens.
Mtext bounding boxes can be edited directly through grips:
Options within the command
- 对正
- Specifies the justification (horizontal alignment) of the text inside the bounding box.
- 旋转角度
- Specifies the rotation angle of the text block. Positive angles rotate the text block counter-clockwise.
- text Style
- Specifies the text style to use. See Style command.
- text Height
- Specifies the height of the text.
- 方向
- Specifies the direction in which the bounding box is expanded.
- Left-to-right
- The text is placed at the left and expands the bounding box to right.
- Top-to-bottom
- The text is placed at the top and expands the bottom of the bounding box.
- By-Style
- Uses the direction defined by the text style.
- 宽度
- Specifies the width of the bounding box.
- 行间距
- Defines the line spacing of the text.
- 至少
- Specifies the minimum line spacing factor.
- 精确
- Specifies the exact line spacing factor.
- 列
- Defines the amount of columns.
- 没有栏
- No columns are created.
- 静态
- A fixed amount of columns with fixed dimensions is created.
- 动态
- A dynamic amount of columns is created. The amount of columns depends on the length of the text.
