MTP command
Allows to specify a point as the midpoint.
Allows to specify a point as the midpoint between two points whenever a command prompts to enter a point.
Note: This is a transparent command.
Method
This command works only with commands that prompts to enter a point.
Note: This command sets entity snaps, similar to OSNAP
command.
Options within the command
- First point of mid
- Identify the first reference point.
- Second point of mid
- Identify the second reference point.
