MTP command
Allows to specify a point as the midpoint.
Allows to specify a point as the midpoint between two points whenever a command prompts to enter a point.
Note: This is a transparent command.
Method
This command works only with commands that prompts to enter a point.
Note: This command sets entity snaps, similar to OSNAP command.
Options within the command
First point of mid
Identify the first reference point.
Second point of mid
Identify the second reference point.
