OLEOPEN command
Opens the selected OLE object.
Opens the selected OLE object in the source application for editing. (short for "object linking and embedding linking"). If the link between the drawing and the source application is broken, the OLE object cannot open.
Note: Use the InsertObj command to insert OLE objects in
drawings.
Note: The command is only available on the windows
platform.
