OOPS command
Restores the last erased entity.
Alias: UNDELETE, UNERASE
Restores the last erased entity, including those erased by the Block command. If there are no erased entities in the drawing, BricsCAD indicates: There is nothing to un-erase.
This command displays no prompts and has no options.
