PARAMETERSPANELCLOSE command
Closes the Parameters and constraint panel.
Closes the Parameters and constraint panel to hide it from the current workspace. If the Parameters and constraint panel is stacked when you close it, the Parameters and constraint tab or icon is removed from the stack.
