PASTEORIG command
Pastes entities from the clipboard into a different drawing.
Icon:
Note: Before you can use this command, first use the COPYCLIP
or COPYBASE commands to copy entities from the current drawing.
Pastes CAD entities from the Clipboard into a different drawing using the coordinates of the entities in the source drawing. PASTEORIG comes from "paste at original coordinates".
Note: This command does not paste entities back into the
source drawing.
