PDFATTACH command
Opens the Select PDF underlay file dialog box.
![BricsCAD Lite; BricsCAD Pro; BricsCAD Mechanical; BricsCAD BIM](https://static.bricsys.com/help/images/V23/en_US/command-reference-lite-pro-mechanical-bim.png)
Icon:
Opens the PDF underlay file dialog box to select a PDF file to reference into the current drawing. After selecting the file and choosing Open, the Attach PDF Underlay dialog box displays. It enables you to specify where and how to attach the PDF file.
