PEDITEXT command
Edits vertices and segments of a polyline.
Icons:
Edits vertices and segments of a polyline interactively, without first selecting the polyline.
Note: This command was meant for use with the Quad cursor. See the related procedure Editing a polyline using the Quad on how to use this command with the Quad.
Options
Add vertex
Adds a vertex to the selected segment.
add vertex at the End
Adds a new vertex at the end of the polyline.
adjust Bulge
Modifies the bulge factor of the selected segment.
Remove segment
Deletes the selected segment.
Stretch segment
Moves the selected segment.
Stretch Vertex
Moves the selected vertex.
