POINTCLOUDALIGN command
Rotates the point cloud to optimally align it with the X and Y axes.
Icon:
Rotates the point cloud to optimally align it with the X and Y axes in the world coordinate system. This enables you to efficiently create and edit entities relative to the point cloud using common tools such as orthogonal and polar tracking.
Options within the command
Select point cloud entity
Allows to select a point cloud entity if the current drawing has more than one point cloud attached.
Note: If the current drawing has only one point cloud attached, it is automatically selected for the align operation.
First corner point
Specify the first corner of a rectangular selection window.
Specify opposite corner
Specify the opposite corner of a rectangular selection window.
