POINTCLOUDATTACH command
Attaches point cloud files to the current drawing.
Icon:
Method
Select a file or a folder, specify Point cloud data name, give unit for point coordinate and then attach it from the Attach Point Cloud dialog box.
The point cloud file or folder is preprocessed in the background and a balloon message arising when is ready.
Note: The POINTCLOUDCACHEFOLDER system variable sets the
folder where the point cloud data are stored.
Options within the command
- File
- Opens the Pre-process point cloud data file(s) dialog box from where you have to select a point cloud file to attach.
- Folder
- Opens the Choose input folder dialog box from where you have to select a folder to import.
