POINTCLOUDCOMPRESS command
Compresses a point cloud cache entry.
Method
Opens the Please provide a point cloud cache dialog box where you can select a point cloud cache folder. Inside the selected folder, data files at the relative path Data/*.pnt will be compressed. The extension of the data files will change from .pnt to .pnz.
The compression ratio is displayed on the Command line.
Note: If FILEDIA =0, you have to specify the location of the
point cloud cache folder in the Command line.
Note: Manual compressing and decompressing a point cloud cache file may be needed in
case of data exchange between BricsCAD® V21 and V22 versions.
BricsCAD® V22 can work
seamlessly with compressed or uncompressed data, but BricsCAD® V21 only works with
uncompressed data.
Note: Set the POINTCLOUDCACHEFOLDER system variable as you
prefer.
