POINTCLOUDCROP command
Creates a crop boundary on a point cloud.
Icons:
Creates a crop boundary on an attached point cloud to limit the displayed points to a specific area. If the current drawing has only one point cloud attached, it is automatically selected for the crop operation. If the current drawing has more than one point cloud attached, you are prompted so select which point cloud to crop.
方式
Crops a point cloud entity, displaying only the part of the point cloud inside or outside a prismatic or cylindrical volume.
Options within the command
- 矩形
- Creates a rectangular prismatic cropping.
- 圆形
- Creates a cylindrical cropping
- 多边形
- Creates a polygonal prismatic cropping.
- 反转
- Inverts the current cropping. Toggles between Inside/Outside.
- 内侧
- Displays the part of the point cloud inside the volume only.
- 外部
- Displays the part of the point cloud outside the volume only.
- 显示切换(T)
- Toggles the current cropping on/off.
- 移去最后(L)
- Removes the most recently added cropping volume.
- 移除所有(A)
- Removes all cropping.
