POINTCLOUDCROPSOLID command
Converts an extruded solid/polysolid to a crop solid.
Icon:
Note: 裁剪实体可用于以3D裁剪点云,并且可以像任何其他BricsCAD实体一样进行修改。
方式
There are two methods to convert solids or polysolids to a crop solid:
- 内侧
- 外部
Options within the command
- 内侧
- Converts the selected solids into inside crop solids.
- 外部
- Converts the selected solids into outside crop solids.
Note: You can switch the Inside/Outside cropping property of a crop solid from the Properties panel.
