POINTCLOUDFITPLANAR command
Creates a planar surface or a solid.
Icon:
描述(D)
Searches a point cloud for a dense set of points and creates a planar surface or a solid.
Note: The command can be executed in model view or in a bubble view. Double click the bubble you want to start the command in.
Options within the command
- 选择点云实体
- Specifies point cloud entity where to search.
- Select point cloud in model view
- Specifies point cloud entity where to create a planar surface or solid.
- 接受
- Accept current planar surface or solid.
- 拒绝
- Decline current planar surface or solid.
- 模式
- Switches between rectangular (1), contour (2) or solid (3).
- 撤销(U)
- Removes the most recently added surface from the current selection. Use Decline to remove the surface that was selected first.
- 在气泡查看器中选择点或切换气泡
- Specifies point in bubble viewer where to create a planar surface or solid.
- 气泡
- Switch between bubble viewers. Select bubble to switch to.
- 切换
