POINTLIGHT command
Places point lights.
Icon:
描述(D)
Places point lights for use with renderings. A point light represents sources that illuminate in all directions, such as a bare lightbulb, and it so has no target.
Note: Unlike all other light types, point lights do not have a target or vector associated with them. Drawings can have more than one point light.
Options within the command
- 名称(N)
- Specifies a name for the light so that it can be identified by the LightList command.
- 强度系数
- Specifies the intensity of the light.
- 状态
- Toggles the use of this light.
- 光度
- Specifies the photometric properties of the light.
- 强度
- Sets the intensity expressed in candela.
- 通量
- Sets the luminous flux expressed in lumens.
- 照度
- Sets the illuminance expressed in lux or foot-candles.
- 距离(D)
- Sets a distance expressed in drawing units.
- 颜色(C)
- Sets the color.
- Lists the names of available colors.
- 开氏温度
- Sets a color temperature expressed in degrees Kelvin.
- 阴影
- Specifies the look of shadows cast by this light.
- 关闭(O)
- Disables the calculation of shadows for the light.
- 鲜明
- Displays shadows with sharp edges. Use this option to increase performance.
- 柔和贴图
- Displays realistic shadows with soft edges.
- 柔和采样
- Displays realistic shadows with softer shadows based on extended light sources.
- 造型
- Sets the shape of the light.
- 圆盘
- Sets the radius of the disk.
- 矩形
- Sets the length and width of the rectangle.
- 样本
- Specifies the sampling size of the shadow.
- 可见
- Toggles the shape visibility.
- 衰减
- Specifies how the illumination falls off with distance from the light.
- 衰减类型
- Specifies the type of attenuation.
- 无
- No attenuation so that the distance to the light source has no influence.
- 线性反比
- Attenuation is the inverse of the linear distance from the light.
- 平方反比
- Attenuation is the inverse of the square of the distance from the light.
- 使用限制
- Toggles whether the extent of the illumination is limited.
- 衰减起始限制
- Defines the point where the light starts to shine, measured from the center of the light.
- 衰减终止限制
- Defines the point where the light stops to shine, measured from the center of the light.
- 筛选颜色
- Specifies the color of the light.
- 索引颜色
- Specifies an Index color.
- Hsl
- Specifies the color using three parameters Hue, Saturation and Lightness.
- 颜色薄
- Specifies a bookcolor name.
