POLYSOLID command
Creates a 3D solid in the shape of a wide, extruded polyline.
Icon:
Alias: PSO
描述(D)
Creates a 3D solid in the shape of a wide, extruded polyline with multiple line and arc segments. Options allow you to specify the width, height and justification.
Methods to create a polysolid
This command has 2 methods to begin creating a polysolid:
- 起点
- 实体
- 起点
- Begin creating a polysolid by specifying a start point for the base path then:
- Set next point:
- Specify the next vertex of the base path.
- 指家聚合实体的高度
- Specify the height of the polysolid.
- 实体
- Begin creating a polysolid by selecting a 2D entity (line, open or closed polyline, arc, circle, ellipse, elliptical arc, or splines) as the base path then:
- 指家聚合实体的高度
Additional options within the POLYSOLID command
After you begin creating a polysolid, the following options may be available:
- 高度
- 宽度
- Specify the width of the polysolid.
- 对正
- Specify the position of the polysolid with respect to the base path.
- Left: the left edge of the polysolid follows the base path.
- Right: the right edge of the polysolid follows the base path.
- Center: the center of the polysolid follows the base path.
- Hot Key Assistant
- When Hot Key Assistant (HKA) is enabled, the following widget allows you to dynamically switch between left, center, and right justification by pressing the Ctrl key.
- 独立实体
- Specify whether polysolid creates an individual 3D solid for each segment or a single 3D solid for all the segments.
- On: create individual solids.
- Off: create a single solid.
- 动态
- Specify whether you are prompted to specify the height when creating a polysolid.
- On: you are prompted to specify the height.
- Off: the height is defined by the PSOLHEIGHT system variable.
- 绘制弧
- 指定弧的终点
- Specify the next vertex of the polysolid.
- 第二点
- Specify a point along the polysolid arc’s circumference.
- 绘制直线
- Specify the end point of a polysolid line segment. The line segment is drawn tangent to the previous segment.
- 距离(D)
- Specify the length and angle of a polysolid segment.
- 跟随
- Begin creating a polysolid from the last drawn arc or line segment, following its angle.
- 撤销(U)
- Undo the last polysolid segment and continue drawing from its previous start point.
- 关闭
- Automatically draw a polysolid segment from the end point of the last segment to the start point of the first segment. This ends the command.
