PREVIEW command
Displays the Preview window so that you can check how the drawing looks before plotting it.
Icon:
Alias: PREVIEW, PRE
Note: This command does not work with the "None" printer; use
the PRINT or PAGESETUP command to first specify a printer.
Displays a window:
Use the mouse scroll wheel to zoom and use the scroll bars to pan.
- 1. Print
- Prints the drawing; does not display the PRINT dialog box. See PRINT command.
- 2. Print Settings
- Displays the PRINT dialog box. See PAGESETUP command.
- 3. Zoom
- Changes the size of the preview.
