PROPULATE command (Express Tools)
Lists, removes or updates drawing properties data.
Icon:
Allows you to list, remove or update drawing properties data. Using a template, the drawing properties data can be added to folders of drawings. If a customized template is used it is possible to extract attribute values from title blocks to the drawing properties. The information that can be extracted are attribute values of blocks and lists of attached xrefs, images and fonts.
Options within the command
- Active template
- Opens the Select Propulate Template File dialog box that allows you to select a propulate template file that is used to update drawing properties fields.
- Edit template
- Opens the Edit Propulate Template dialog box that allows you to create and edit propulate template files.
- List
- Allows you to choose between Current drawing and Other drawings.
- Remove
- Removes the drawing properties from the current drawing or a specified drawing.
- Update
- Propulates the drawing properties from the current drawing or a specified drawing using the active template.
