PSBSCALE command (Express Tools)
Sets or updates the scale of block references relative to paper space.
Method
For the inserted blocks in model space, you can specify the size they should be displayed in paper space.
Note: Use the Update option to adjust previously set entities, in case the zoom factor changes.
Options within the command
Set
Specifies the X and Y scale factor relative to paper space.
XYZ
Specifies the X, Y and Z scale factor relative to paper space.
Update
Updates the scale of the selected block reference.
