PURGE command
Removes unused named entities from drawings.
Icon:
Alias: PU
Method
Specify which type of entities to purge.
Options within the command
- BAtch all
- Purges all unused named entities from the drawing without prompts.
- purge All
- Purges all unused named entities from the drawing following the prompts.
- Yes
- Purges each unused named entity after you confirm.
- No
- Purges all unused named entities without confirmation.
- Blocks
- Removes unused block definitions from the current drawing.
- DEtail view styles
- Removes unused detail view styles.
- Dimension styles
- Removes unused dimension styles from the current drawing.
- Groups
- Removes unused named groups from the current drawing.
- LAyers
- Removes unused layers from the current drawing.
- LineTypes
- Removes unused linetypes from the current drawing.
- MAterials
- Removes unused materials from the current drawing.
- MLine styles
- Removes unused multiline styles from the current drawing.
- MUltileader styles
- Removes unused multileader styles from the current drawing.
- Plot styles
- Removes unused plot styles from the current drawing.
- Regapps
- Removes unused regapp keys from the current drawing.
- SEction view styles
- Removes unused section view styles from the current drawing.
- SHapes
- Removes unused shapes loaded into the drawing with the Load command.
- Table styles
- Removes unused table styles from the current drawing.
- text STyles
- Removes unused text styles from the current drawing.
- Visual styles
- Removes unused user-defined visual styles from the current drawing.
- Zero-length geometry
- Removes geometry with no length.
- Empty text entities
- Removes empty text entities from the current drawing.
- Orphaned data
- Performs a drawing scan and removes unused DGN linestyles data.
