QPRINT command
Prints the drawing using the default print configuration.
Icon:
Allows printing a drawing without displaying the Print dialog box (short for "quick print").
If there is no printer added as a default printer a warning message will appear.
You will want to configure the drawing's print properties ahead of time with the PageSetup command.
