QSELECT command
Opens the Properties panel in Quick select mode.
Icon:
Opens the Properties panel in Quick Select mode to display it in the current workspace. The Properties panel appears at the same size and location that it did before it was closed or collapsed. Like any other dockable panel, the Properties panel can be either floating, docked or stacked.
