QTEXT command
Toggles the QTEXTMODE system variable.
Alias: QT
Toggles the QTEXTMODE system variable to display text entities as rectangles or text. You must use REGEN or REGENALL to see the change.
  • On: turns on the QTEXTMODE system variable.
  • Off: turns off the QTEXTMODE system variable.
  • Toggle: changes the QTEXTMODE system variable to the opposite of the current setting.
