RECSCRIPT command
Opens the Record script dialog box.
Icon:
描述(D)
Opens the Record script dialog box to save data from the current drawing to an scr file. After choosing Save in the dialog box, the commands and pick point you specify in the drawing editor are recorded in the scr file until you run the STOPSCRIPT command.
