RECTANG command
Creates a polyline in the shape of a rectangle.
Icon:
Alias: REC, RECT, RECTANGLE
描述(D)
Creates a closed, four-sided rectangular polyline Insert link to Polyline Entities article in the shape of a rectangle, square, and variants with chamfers or fillets.
Methods to create a rectangle
This command has 5 methods to begin creating a rectangle:
- Select first corner of rectangle
- 旋转(R)
- Square
- 面积(A)
- Dimensions
Additional options: [Chamfer/Fillet/Elevation/Thickness/Width of line]
- Begin creating a rectangle by specifying a corner of a rectangle then:
- 矩形的其他角:
- Specify the opposite corner of the rectangle. The rectangle is drawn parallel to the x and y axes.
- 旋转(R)
- 矩形的其他角:
- Rotation angle for rectangle
- Specify the rotation angle of the rectangle.
- Square
- Begin creating a rectangle by specifying a corner of a square then:
- 指定方形的第二个角点
- Specify a corner along the same side of the square to define its length and angle.
- 面积(A)
- Begin creating a rectangle by specifying its area then:
- Calculate rectangle dimensions based on [Length/Width]
- Choose whether to use the length or width to calculate the dimensions for the rectangle.
- Length: enter rectangle length
- Width: enter rectangle width
- 标注
Begin creating a rectangle by specifying its length then:
- 输入矩形宽度
- Specify the width of the rectangle.
- Specify the first corner of the rectangle.
Options within the RECTANG command
After you begin creating a rectangle, the following options may be available:
- 倒角(C)
- Specify the first chamfer distance to use for all rectangles then:
- 指定矩形的第二个倒角距离
- Specify the second chamfer distance to use for all rectangles
- 圆角(F)
- Specify the fillet distance to use for all rectangles.
- 标高(E)
- Specify the height above the xy-plane to use for all rectangles.
- 线宽
- Specify the width of the rectangle line segments. All segments have the same width.
- 厚度(T)
- Specify the thickness of the rectangle line segments. All segments have the same thickness.
- 关闭倒角
- Turn off chamfer.
- Turn fillet off.
- Turn off fillet.
- 使用默认值
- Reset the default value.
