REDO command
Reverses the action of the previous U or UNDO command.
Icon:
Reverses the action of the previous U or UNDO command to restore entities to their state prior to the U or UNDO operation. The REDO command only works immediately following the U or UNDO commands.
This command displays no prompts and has no options.
