REGION command
Creates regions.
Icon:
Alias: REG
描述(D)
Creates regions from closed entities or sets of entities that enclose a space.
Options to create a region
This command has 1 option to begin creating a region:
- Select entities or boundaries
You can continue creating regions until you press Enter to end the command.
- Begin creating a region by selecting closed entities or sets of entities that enclose a space. Each closed entity or set of entities produces a region. Depending on the current value of the DELOBJ system variable the original geometry is deleted or retained.
Options within the REGION command
Selection options (?)
