RTROTX command
Rotates 3D drawings in real-time about the x axis.
Icon:
方式
The rotation cursor is displayed during real-time rotation. Hold down the mouse’s left button and then move the mouse to rotate the drawing in real-time.
Note: The ORBITAUTOTARGET system variable determines if the viewpoint rotates around your pick point or the center of the object.
Context Menu Options
Right-click to display the context menu to switch viewing mode.
- 平移
- Pans the drawing in real-time. Starts the RTPAN command.
- 缩放
- Zooms the drawing in real-time. Starts the RTZOOM command.
- Constrained sphere
- Rotates the 3D drawing in real-time. Starts the RTROTCTR command.
- 球体
- Rotates the 3D drawing in real-time. Starts the RTROT command.
