SCALE command
Resizes 2D and 3D entities.
Icon:
Alias: SC
方式
You can specify the scale factor by selecting a base point and a length or by typing an explicit scale factor in the Command line.
Note: A scale factor smaller than 1 shrinks the entities. A negative scale factor scales the entities in the negative direction.
Options within the command
- 参照
- Resizes entities using a base or reference scale.
- 复制
- Scales a copy of the selection set, leaving the original entities intact.
