SELECTSIMILAR command
Selects similar entities.
Icon:
Selects all entities with the same properties as the currently selected entity.
Method
Select one or more entities and choose the properties based on which the selection will be made. When you exit the command, the entities that match the properties are shown as dashed and with entity grips.
Note: For this command to operate as intended, at least one property must be selected.
Options within the command
SEttings
Displays a dialog box to select the properties.
Note: Changing the settings in this dialog box changes the value of the SELECTSIMILARMODE system variable, which is accessed through the Settings command.
