SELGRIPS command
Displays entities grips.
![BricsCAD Shape; BricsCAD Lite; BricsCAD Pro; BricsCAD Mechanical; BricsCAD BIM](https://static.bricsys.com/help/images/V23/en_US/command-reference-all.png)
Selects entities and then displays their grips.
BricsCAD highlights selected entities and displays their grips.
Edit the entities by dragging the grips. To select all entities in the drawing, press Ctrl+A.
