SETVAR command
Displays and changes the values of system variables.
Alias: SET
Displays and changes the values of system variables at the Command line.
Note: This command can be entered transparently:
‘SETVAR.
Note: The names of system variables can also be entered
directly at the Command line, without using this command.
Methods
There are two methods to use SETVAR command:
- Enter the name of a system variable to see its state.
- Choose to display a list that contains all the system variable.
Options
- Variable name
- Specify the name of a system variable.
- Lists the names of system variables.
- Lists all system variables.
- Name*
- Lists all system variables starting with Name.
