SHADEMODE command
Specifies the shading style for the current drawing.
描述(D)
Specifies the shading style for the current drawing to be used by the SHADE command.
选项(O)
- 输入视觉样式
- Choose the name of a preset visual style.
- 2d线框
- Default display mode.
- 线框
- Wireframe, which shows all edges.
- 隐藏(H)
- Wireframe with hidden lines removed.
- 仿真
- Rendered with materials, if available.
- 概念
- Rendered with psychographic color range.
- 着色
- Rendered without materials.
- 边框着色
- Rendered with contrasting edges, without materials.
- 灰阶着色
- Rendered in shades of gray, without colors.
- 草图
- Rendered with rough edge lines.
- X射线
- Rendered with semi-transparent faces.
- 其他
- Create a new visual style.
- 当前
- keep the current visual style.
